Какое масло лить в двигатель
Сообщений в теме: 2
#1 Lenin
Lenin
    просто админ
  • Главные администраторы
  • 9545 сообщений
Отправлено 13 April 2009 - 07:07 AM
Можно лить любое масло имеющие допуск 229.1 или 229.3
Масла с сайта Мерседес имеющие эти допуски:
Approved by MB Sheet 229.1 or 229.3
MB sheet 229.1 approved oils
for passenger cars with gas and diesel engines, used to be minimum spec for latest (98+) engines, high detergent, dispersant spec suitable for normal drain intervals. Based on ACEA A3, B3. Note 229.1 oils are not recommended for MB's latest (2002+) 4 valve gas M271, M275, M285 and diesel OM646, OM647, OM648 engines.
Aral Super Elastic 0W-40 Unal
Aral Extra Turboral 0W-40 Unal
Aral BasicTronic 10W-40
Aral SuperTronic 0W-40
Aral HighTronic 5W-40
Aviasynth 5W-40
Avia Turbo CFE 10W-40
BP Visco 5000
Castrol GTD Magnatec 10W-40
Castrol GTX5 Magnatec 10W-40
Castrol GTX3 15W-40, 15W-50, 20W-50, 10W-40
Castrol GTX2 15W-50
Castrol GTX 15W-50
Castrol GXL 10W-40 ACEA A3/B3
Castrol Formula RS 0W-40
Castrol GTX3 Professional 15W-40 (Castrol's best mineral oil)
Castrol GTD 505 01 TOPUP 5W-30
Chevron Supreme SAE 5W-40
Chevron Supreme Semi-Synthetic SAE 10W-40
Elf Excellium 0W-40
Elf Synthese
Esso Ultra
Esso Uniflo
Fuchs Titan Supersyn SL 0W-30, 0W-40, 5W-40
Fuchs Titan UNIC MC 10W-40
Fuchs Titan UNIC Plus MC 10W-40
Havoline Synthetic 5W-40
Havoline Formula3 X1 Extra 10W-40
Havoline Formula3 X1 Diesel Extra 10W-40
Hellas Super Synto 0W-40
Hellas Hermes Plus 15W-50
Kendall Motor Oil Elite 0W-40
Liqui Moly Diesel Synthoil 5W-40
Liqui Moly High Tech 5W-40
Liqui Moly HC7 5W-40
Mobil 1 with SuperSyn 15W-50
Mobil 1 TriSynthetic 5W-50, 15W-50, 0W-40, 5W-40 (100% synthetic)
Mobil Super M 15W-40 (mineral)
Mobil Super S 5W-40 and 10W-40 (mineral w/ synth additives)
Motul 6100 Synergie 10W-40
Motul 4100 Turbolight 10W-40
Pentosin Pentosynth TS 10W-40
Pentosin Pentosynth 5W-40
Pentosin Pentoturbo 15W-40
Pentosin Diesel 10W-40
P.O. Zirve
P.O. Zirve Ekstra
Pennzoil Synthetic European Formulation 5W-40
Performanx Full Synthetic Motor Oil 5W-40
Schaeffer Micron Moly 5W-30
Schaeffer Micron Moly 10W-40
Schaeffer Supreme 7000 10W-30
76 Pure Synthetic Motor Oil 5W-40
Shell Helix Ultra 5W-30
Shell Helix Plus 5W-40
Shell Super Motor Oil 10W-40
Sunoco Forza SAE 15W-40
Ultra Turbo Semi-Synthetic Motor Oil 0W-40
Valvoline All Fleet Extra 15W-40, 20W-50, 10W-40
Valvoline SynPower
Veedol SUPER X-TRON 10W-40
Veedol SUPER X 15W-40
MB sheet 229.3 approved oils
for passenger cars with gas and diesel engines with extended drain interval indicator FSS up to 20,000 km, or 40,000 km - 25,000 mi, current minimum spec for 1998+ MB engines, min. 1.0% fuel saving compared to 229.1, based on ACEA A3 B4. For gas engine of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with diesel particulate filter).
AGIP EXTRA HTS 5W-40
AGIP Synthetic PC 0W-40
AGIP Eurosport 0W-40
Amsoil 5W-30 Synthetic Motor Oil
Amsoil 10W-30 Synthetic
Amsoil Series 3000 5W-30 Heavy Duty Diesel
Aral SuperSynth 0W-40
Aral Super Tronic 0W-40
Aviasynth 0W-40
Castrol DCO TOPUP SAE 0W-30
Castrol Formula RS Road and Track 5W-40
Castrol GTX7 DYNATEC 5W-40
Castrol Formula SLX 0W-30
Castrol TXT SOFTEC PLUS 5W-30
CIFAB Synthoil Hydrocrack HC7 5W-40
Elf Excellium LDX SAE 5W-40
Esso Ultron 0W-30 (fuel economy)
Esso Ultron 5W-40
Fuchs Silkolene Pro S 5W-40 - 100% Synthetic Oil For All Race Engines
Fuchs Silkolene Pro S 10W-50 - 100% Synthetic Oil For All Race Engines
Fuchs Titan SuperSyn SL 0W-30
Havoline Synthetic DS 0W-30
Kendall GT-1 Full Synthetic 5W-40
LUKOIL SYNTEETIK 5W-40
Mobil 1 SuperSyn European Car Formula 0W-40
Mobil 1 SuperSyn 5W-40
Mobil 1 SuperSyn 5W-50
Mobil 1 Turbo Diesel 0W-40
Mobil Synt S 5W-40
Mobil Synt S Turbo Diesel 5W-40
Mobil Syst S 5W-40
Motul 8100 E-Tech 0W-40
Motul 8100 X-cess 5W-40
Pentosin Pentospeed 0W-30 VS
Q8 Formula Excel 5W-40
Quaker State Full Synthetic European Formulation 5W-40
Schaeffer Micron Moly 5W-30, 10W-40
Schaeffer Supreme 7000 5W-30, 10W-30, 20W-50
Shell Helix Plus S 5W-40 (Mercedes-Benz)
Shell Helix Ultra 5W-30, 0W-40, 5W-40
Sunoco Synturo Gold 5W-40 (introduced January 2002)
Total FINA First 5W-40
Total Quartz 9000 5W-40
Valvoline DuraBlend MXL 5W-40
Valvoline SynPower MXL 0W-30
Valvoline SynPower 5W-30, 0W-40, 5W-40, 20W-50
Veedol POWERTRON 5W-30
Veedol SYNTRON 0W-30
#2 Lenin
Lenin
    просто админ
  • 9545 сообщений
Отправлено 02 October 2009 - 06:58 AM
Про расход масла
http://kyron-clan.ru...p?showtopic=822
Про выбор масла для дизеля
http://kyron-clan.ru...?showtopic=1150
#3 Andro
Andro
    Удав
  • Правление Клана
  • 3911 сообщений
Отправлено 30 June 2014 - 01:06 PM
Допуски масла MB
читать здесь
